Often times we hear of original bolt and nut finishes as being described as phosphate, zinc, or cadmium. However, there were actually many different finishes used for original GM bolts and nuts. Here are examples of a few [none for sale]:
Some GM bolts have what GM specified as a plain finish. Some folks think this is a natural steel finish. However, it's NOT. A plain finish is very similar to what are often described as black phosphate. These finishes, thus, are easily confused and mis-described. The following pictured bolts and nut are all of plain finish. As far as I know none of these were used on a Corvette but they are pictured only to show a typical plain finish. Although it's unimportant, these are, from left to right, GM #9430262, 454867, 9422369, 3799830, 271629, and 14054921:
The following bolt has a zinc-organic finish. This is a GM #9439920. This finish is sometimes described as "dull zinc" but it's actually different than a pure zinc finish which is usually much brighter.
The following bolt has a phosphate-zinc-organic finish. It's GM #9439920:
The following nut was used on 1965-82 Corvettes. It is a GM #102647 or, possibly, GM #274428 and is of plain finish. It was used for the p/s ram to relay rod, idler arm to relay rod, control valve to pitman arm and relay rod to pitman arm. It was also used for the upper ball joint stud.
The following nut is a GM #9422298. It was used for the idler arm-to-frame bracket bolts. It is of zinc finish:
