Rally Wheels 68 - NCRS Discussion Boards
Rally Wheels 68
  • Emmanuel G.
    • February 14, 2021
    • 1
    Rally Wheels 68
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: Rally Wheels 68
    Emmanuel , welcome to the Tech Board. All 1968 Corvettes came with 7" Rally Wheels, even the L-88. Your wheels should have the code letters AG stamped on them just to the right of the valve stem if they are original assembly line or GM replacement wheels.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
      • 15610
      Re: Rally Wheels 68
      The '68 Corvette Rally wheels are unique to that year and the Y-body. There was another 7 x 15 Rally wheel in the same era that was used on the G-body, but it had zero offset. The AG wheels have -0.28" offset to provide rear wheel/tire clearance to the leaf spring ends. Use of the zero offset G-body 7" Rally wheels may cause interference, so be sure if you buy repro wheels that you get the correct negative offset Rally wheels for Corvettes.
