Gary
Pitman arm nut and socket size
Re: Pitman arm nut and socket size
The original nuts are thinner then new ones. I use 1 5/16 socket on all of them without a problem. I always install a new nut and torque them to 145-150ft/lb with new lock washer. I will check both new and original when I go back out to my shop and let you know the dimensions.😀 1- Top
I checked an original 7/8-14 nut and a new one I use as well as the 1 5/16 3/4" drive socket I use.
original nut= .439 thick, 1.305 hex across the flats
new nut= .500 thick, 1.305 across the flats
socket - 1.350 between flats, I don't have a metric socket to compare but never had a problem torquing the nuts.
Then I checked the nut on an original 68 box I am starting on today- same size as the original nut I previously checked.- Top
Gary,
The 33 mm socket I just bought is 1.308” between flats. It fits the 1.280” nut from Long Island Corvette much better than a 1-5/16” socket, which as you measured is 1.350”, not the nominal 1.3125” value. For the 1.305” nuts you buy, the 33 mm socket might be too tight of a fit.
Gary
Gary------
I have had this problem with the fitment of the 1-5/16" socket on the pitman arm retaining nut. I consider the fitment of the nut in the socket to be "sloppy". However, a 1-5/16" socket will work but I use only a 6 point socket, never a 12 point. The industry standard across-the-flats size for a 7/8-14 nut (which is what the pitman nut is) is 1-5/16".
Unknown to many, there were actually 2 different nuts used. 1963-74 used nut GM #258779 which is an ancient part number. 1975-82 used nut GM #5667628. The former was discontinued in April, 1975 and replaced by the latter for SERVICE of all 1963-74 Corvettes. I actually have examples of both nuts and they appear to be identical in every way. Measured with my digital caliper I find both to be 1.285" across-the-flats. This is actually equivalent to 1-9/32". Once-upon-a-time I looked for a socket of that size and never found one.
A 1-5/16" 6 point socket is 1.3275" across-the-flats. With the pitman nut at 1.285", I think this explains the sloppy fit. But, it will work. The 33mm socket might be a better solution.In Appreciation of John Hinckley- Top
And lots of blackout on it still which I believe GM used.
