Pitman arm nut and socket size - NCRS Discussion Boards
    Re: Pitman arm nut and socket size
    Originally posted by David Bartush (3288)
    Part #s really help: 258779 & 5667628 are Saginaw Steering Gear Division numbers used by all GM Divisions. Listed in GRP. 6.861
    David------
    Since the two are apparently the same in configuration, I suspect that the difference is material grade with the 258779 being 280-M and the 5667628 being 300-M.
    • Gary B.
      • February 1, 1997
      • 6979
      Joe,
      So there are no visible markings (e.g., dots) or finish color differences between the grade 5 and grade 8 version of that nut?
      Gary
        #18
        Originally posted by Gary Beaupre (28818)
        Joe,
        Gary
        Gary------
        I don't know, for sure, if there was a material grade difference between the 2 nuts; I'm just postulating that. During the time period of the PRODUCTION change GM was converting other chassis fasteners from 280-M to 300-M. So, I'm just "extrapolating" on that.
        In any event, I can see no markings on either which might indicate material grade. Both appear to be "plain" finish.
