65,327/300
Just got my rebuilt engine back and am about ready to install. I have 2 questions.
1. Distributor is installed and I checked that dimple is towards rotor. Rotor is pointing towards approximately #4 when distributor is in block. When cap is installed installed #1 wire lines up perfectly so I would like confirmation that this is correct. Engine is set on compression stroke and about 8 degrees advance. I also used a meter and on the points and they just started to open so the distributor is locked down in that position.
2. The car never had the micarta spacer installed and I put one when reinstalling the carb. It is .400 thickness. Fuel filter is sitting at a fairly severe angle towards the front of engine and nothing I do can get the filter level. All fuel lines from pump to carb are correct. I'm about ready to remove the spacer and just go like it was before rebuild. Any thoughts would be appreciated. Thanks
Bill B.
Bill B.
