I’ve searched the TDB archives and Google and found no information about bolt GM #9416253, which is used in ‘66 and ‘67 to attach the shifter mount to the crossmember (item #3 in AIM image). The repro bolt I bought is bright zinc, but nearly all of the repro nuts, bolts, and washers for the shifter and transmission mounts are incorrect bright zinc, I’m suspicious about the bright zinc for the repro if 9416253. Does anyone have direct knowledge about the finish for the GM bolt?
While I’m focused on that area of my restoration, can I also get confirmation that bolts GM 9419073 (item 5 in AIM image) and 454933 (item 9 in AIM image) are both black phosphate? That’s what I read in the archives. Those two bolts came as bright zinc in the repro kits I purchased.
Gary
Gary
