I have a bunch of Headlamp assembly's I'm piecing together to make two for my March Built 1969. The newest Judging Guide has it pretty a clear description of what I should be looking for.
The early 68's had the 1/4 tubes offset and both facing the LH side. Then it goes on to state that late 68's and all 69's had the 5/16" Tubes.
Ok so I have a 1/4" Tube Actuator that has the Tube Centered and not offset. Where does it fall it ? I'm being told by a number of sources that the 5/16 Tubes didn't start till 1970. And that the Centered 1/4" Tube is correct for a 69. The easy way would be to just build it according to the Guide, and use it to prove its correct. But there is some doubt here as I'm at a point where I can go either direction.
