Looking for T-top weather strip retainer screw and cage nut replacement solution - NCRS Discussion Boards
  • Roger C.
    • March 1, 1998
    • 83
    I hope I can explain this clearly enough to get some repair solution ideas.
    My 1973 T-Top used 4 screws to retain the window side weather-strip retainer. The screws and cage nut were rusted together.
    Trying to remove the 10/24 screws, the screws twisted off leaving the cage nut unusable.
    Now I am going to have to improvise a way to secure the retainer to the T-top.
    Each cage nut is held in place by two rivets.
    My first step is to figure out how to remove the cage nut assembly. I drilled out the rivets, but the cage nut seems to be glued to the T-top.
    My second task is to figure out a method to replace the cage nuts with another type of fastener.
    I would appreciate any ideas for a solution.
    Thank you
    Roger
    • 11608
    Re: Looking for T-top weather strip retainer screw and cage nut replacement solution
    I drilled out the cage nut itself and tapped the new hole. The hole isn't quite in the exact location of the original, but you can't tell and it works fine.
