(Purists may cringe now)
I recently installed LED headlamp bulbs in H4 glass housings in my '67 to replace the dim incandescent bulbs. The stock headlamps are pretty dim, especially when driving at speed on a dark road.
I bought an H4 halogen lighting kit from Octane Lighting (includes 4 glass housings, and 4 H4 halogen bulbs). I then swapped out the halogen bulbs for Auxito LED's,
The improvement in lighting with LED is remarkable! Night time driving is much safer, as I can see much better down the road.
But, one little problem remains. The headlights will 'flicker' momentarily whenever I apply another electrical load (e.g. brake lights, turn signal, power window, etc.) The flicker lasts only a fraction of a second, so isn't really a safety issue. But it's a bit annoying so I'd like to figure out how to eliminate it.
My understanding is the LED's draw less power than the stock incandescent headlamps.
What is causing the flicker? Do I need to install relays or something along those lines to eliminate this?
Thanks.
Thanks.
