useing motive bleeder .when do i bleed the master usesing the bleeders on the master.before I do wheels or after I do wheels
67 corvette brakes every thing new poor pedal/
Re: 67 corvette brakes every thing new poor pedal/
Gerry,
The master cylinder needs to be bled first, then bleed each caliper. Most people bench bleed the MC before it is installed but you can do it either way.
Here is a procedure written by Duke Williams on bleeding. This and many other documents and procedures can be found in the restoration document repository
https://www.forums.ncrs.org/attachme...0&d=1499375205
Tom- Top
If your only one person ,Bench bleed the Master Cyl. keep master full with fluid at all times, then open all bleeders and let it gravity bleed until air bubbles gone and retightened bleeder.- Top
Duke williams I read your post on brake bleeding,and I'm going to try it.However there is no mention about the bleeders on the master cylinder Do I try to bleed the master useing them?Do I use them to start the bleeding process,Help me if you can thanks- Top
Hi John,
It is located at the top of the home TDB page as a "STICKY" Post called Database of Restoration Documents started by Rich Mozzetta...this link should take you there as well....
https://www.forums.ncrs.org/showthread.php?117966-Database-of-Restoration-Documentsthx,
Mark- Top
Since each rear brake caliper has 2 bleeders, does it matter whether you bleed the outer or inner of the 2 ?- Top
Always bleed the high's point bleeder on each Calipers, there should be one bleeder, lower ones should have a plug fitting on it.IMG_3360.jpg- Top
Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
I usually bleed the outer bleeder valve first, but I doubt it really matters.
(It's working on the advice to do the furthest from the master cylinder first.)- Top
My method is working on the advice to do the closest from the master cylinder first. 😁Mark Edmondson
Dallas, Texas
Texas Chapter
I do both at the same time...gravity style. 2 clear hoses equal length, connected to a Tee to another hose to a bottle. Both rears and fronts at the same time.
Rich- Top
- Top
- Top
