Just purchased a '70 LT-1 and would like to know if 100LL fuel will work well. I found a regional airport willing to sell it as long as I fill up in a container.
Fuel for '70 LT-1
Re: Fuel for '70 LT-1
Thanks Tim! Its only $4.30/gal so I will probably run it straight. This is also a car that I won't drive much. I know some guys that mix 110 octane with pump gas. I just wasn't sure if the low lead fuel was appropriate for the high compression engine.- Top
Keith------
Have you tried using pump premium---91 or 93 octane? If that runs without significant detonation, that's all you need. Higher octane won't be better.In Appreciation of John Hinckley- Top
Keith:Ran the 100LL in my Original 70 LT-1 Camaro Z28 with great results. Once you use this gas YOU WILL NOT GO BACK TO
ANYTHING ELSE. Nothing else will come close. Also will not deteriorate as fast as pump gas. JMHO LarryLarry
LT1 in a 1LE -- One of 134- Top
At the moment I'm running 112 leaded with sunoco ultra 93. 50/50 in my 70 LT-1. Primarily sorting running issues, so I wanted to b.c eliminate fuel as an issue.
My 70 L46 I had since I could get leaded gas at the pump(1973).
Of all the concoctions, 100 LL was the fuel the car ran best with.
20200601_121835.jpg- Top
Where the heck do you find 100 LL avgas for $4.30/gallon?
As others have stated, your engine may run okay on mogas especially if to you have 93 PON available. The actual true CR may be closer to 10.5 than 11 even if the engine was never rebuilt in the field, but most have been with a thicker head gaskets that lowers CR and sometimes "low compression" pistons. The lazy emission control oriented spark advance map may help (but not the ported vacuum advance) to quell detonation, but it also quells a lot of torque, power ,and fuel economy.
Duke- Top
My 70 did fine on 93 unleaded. Maybe just me but did think the engine sounded better on 110 though if you ran it hard.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
I challenge anybody on the following; of course it is JMHO. Buy some 100LL at your local airport in cans.(It is against the law
to fill up a car at the airports pumps. Run enough Pure Av Gas to get all the current fuel out of the car's system so it is running
on Pure Av Gas. I then summit that your C1-C2-Early C3's ORIGINAL(No modifications) Corvette Engines will>START BETTER-IDLE BETTER-RUN AND ACCELERATE BETTER compared to what you are running now. No it is not cheap to buy
BUT>It is the only READILY AVAILABLE FUEL THAT IS CLOSE WHEN COMPARED TO THE FUEL THAT WAS AVAILABLE WHEN YOUR CORVETTE ENGINE WAS MADE. PERIOD. Plus it will stay fresh (less deterioration)then most fuel. Comments Please>Larry
P.S. You will notice the difference in a very short timeLarry
