Coolant Change / Looking for an original hose - NCRS Discussion Boards
  • Keith W.
    • May 25, 2018
    • 193
    Pulled the lower radiator hose to drain the coolant. This junk came out and a good amount of it. The hose is covered in it internally which also has a crack/slice in it. Time to get a new hose. My question is can any of the junk get in the engine and cause issues? It ran great before I pulled the hose off at around 160 degrees. Also, if anyone knows of an original hose I can get my hands on that would be great.
    Re: Coolant Change / Looking for an original hose
    [ATTACH=CONFIG]105420[/ATTACH][ATTACH=CONFIG]105421[/ATTACH][ATTACH=CONFIG]105422[/ATTACH]
    Keith------
    I would suggest doing a complete cooling system flush. A Prestone Flush-and-Fill kit is a convenient way to do this but you'll need to replace the heater hose that the kit's "T" is installed in after the flush if you wish to return to an original configuration.
    Does this car have an aluminum or copper/brass radiator?
    • James G.
      • August 22, 2018
      • 783
      Copper & Brass it's a 9k mile 70 LT1.
      Keith - BTW I see the original embossed fan belts - my car had one of the originals - power steering - I removed it and put on a set of aftermarket belts for driving the car - for shows I reinstall the original - along with the other two repro belts - I did the same with the expensive air filter elements as well.
      James A Groome
      1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
      1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
      My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
      Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
      • Keith W.
        • May 25, 2018
        • 193
        Thanks James. How do I ensure 100% that the hoses I have are original and/or correct? I took both off and have the codes that are on the current hoses. I have been looking at sites for replacements and I can't find the upper hose with that code. My codes are
        upper:
        2806195 AU;
        lower:
        3946854JQ GM AU
        • Leif A.
          • August 31, 1997
          • 3607
          Doc Rebuild has what you need (also, the very best quality). He may still be closed due to the virus.
          69-72 Upper Radiator Hose used with models that wereFactory Equipped with a Copper Radiator70 Upper Radiator Hose with 350 HP,71-72 Upper Radiator Hose with LT-1Repro 1158852 36.00 GM 1159852 39.00
          Leif
          • Jack C.
            • September 30, 1992
            • 1090
            Looks like Bars Leak pellets.
            Jack Corso
            1972 Elkhart Green LT-1 Coupe 43,200 miles
            Top Flight 1994, 2018 & 2021
