Dry Ice Cleaning - NCRS Discussion Boards
Dry Ice Cleaning
  • Mark E.
    • April 1, 1993
    • 4498
    Dry Ice Cleaning
    Has anyone tried this?
    "For vintage car owners that want to preserve undercarriages and engine bays without removing the paint..."
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Mark F.
    • July 31, 1998
    • 1468
    Re: Dry Ice Cleaning
    Has anyone tried this? https://www.hagerty.com/media/mainte...d-undercoating "For vintage car owners that want to preserve undercarriages and engine bays without removing the paint..."
    Hi Mark,
    Thanks for asking this question. I have subscribed to your thread, as I am also very interested in what folks have done in this regard...
    A little web searching yielded the following link pertinent to a Corvette application - there are numerous other sites, too
    I'd also be curious if this process could remove undercoating applied to a Corvette frame (along with rust, too), without removing the frame stencils and colored grease pencil shim marks...
    thx,
    Mark
    • Mark E.
      • April 1, 1993
      • 4498
      I just noticed a "similar thread" below started by Bob Brewer last year. Only one reply from someone who tried it:
      Sal Carbone (8049)
      Join Date November 30th, 1984Posts 380
      Re: DRY ICE cleaning anybody tried it ??
      Yes, I did Dry Ice blasting for a couple of years. Simply stated, its similar to sandblasting only using dry ice pellets as the media in special equipment. It can be very effective in certain instances used with caution. I can see it being extremely useful in underside cleaning of a typical used car. I think it would be too aggressive in a "survivor" type of application. It could easily remove crayon and paint markings, and probably chassis coating and blackout if you're not careful.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Mark F.
        • July 31, 1998
        • 1468
        thanks, Mark - SHUCKS, was hoping for the "Perfect Solution"!
        thx,
        Mark
        • Ronald L.
          • October 18, 2009
          • 3248
          I am keenly interested to know if this will clean the undercoating like Ziebert materials from underbody, fender skirts, etc. as well as full clean up rust on the reinforcments brackets...
          Having said that, one trial I did about 6 years ago to remove an enamel layer and get to an original lacquer layer ...... failed.
          The primer layer is softer and failed - that meant the color layer went with.
          Enamel took twice as long to pull off than Lacquer.
          I did like the look, the fiberglass looked original and non impact abraded.
