Experiencing vibration that begins at 3,800 RPM and progresses up from there. The shop said low compression has been determined in #3 and #6 cylinders but everything else has been checked (drive train, timing, etc.). The vibration occurs whether driving or sitting still, in gear or in neutral. Two outside engine builders (one highly recommended engine builder from the shop and Corvette club and a local racing shop owner) have agreed that it is highly likely something internal. I'm digging for any possibility that it could be something else we've missed, as pulling the motor and doing an investigative rebuild is very expensive. The motor probably has less than a 1,000 miles on it but has sat a lot since it was put together back in the late 80's. I realize it could be a number of things internally - any ideas? I know I am going to want to go above 3,800 RPM every now and then
Thanks in advance.
.Thanks in advance.
