�64 Coupe passenger side window regulator jammed
Stephen,I believe you can disconnect the regulator arm from the bottom glass channel. Now you should be able to raise the glass in the side channels. Use some good duct tape attached to the glass and the top of the door to hold the glass up while you are working on removing the regulator assy.
Thanks. I’ll try that.
After looking at an actual picture of the regulator on a parts web site I think mine may have broken.
I’ll try to pull it out later.
Ok,...it’s later.
After looking inside the door with my small work flashlight it looks like the glass separated from the regulator and is sitting next to the bottom channel at the bottom of the door. I hooked a coat hanger under the window and tried to pull it up. I can get the front to lift about an inch above the door lip, but the rear won’t budge.
Should I detach the front channel?
Jack- Top
- Top
