I am doing a coolant changeout on a 1968 L71 block and have a clearance issue
on the driver's side drain plug. There's no easy way to get it out.
Fortunately, the RH plug is easily accessible.
It looks like the only way to remove this plug is to remove the engine mount nut
and bolt ... or at least remove the nut and drive the bolt back until it's flush with the engine mount.
This will give me the clearance to get a 1/2" breaker bar in there. Right now I'm going
with the breaker bar, coupled to a reducing adapter and a 3/8" hex socket.
The engine was completely rebuilt 10 years ago, so I'm hoping it won't be too difficult.
Assuming I have to take the weight of the motor off of the mount to
do this, how is the best way to support the motor? This is a new one for
me and I'd appreciate any advice on doing this safely and securely.
Thanks!
Russ Trotter
NCRS #15444
Thanks!
Russ Trotter
NCRS #15444
