I'm looking for suggestions to remove oil, grease, and possibly transmission fluid stains from the underbody fiberglass. Discoloration has penetrated the fiberglass over time, possibly the stains cannot be removed.
Is there a method for cleaning the stained fiberglass surface sufficiently for paint without damaging the fiberglass? Are sealers available that would allow painting over these areas once cleaned?
Also, did the factory prepare the C1 underbody pan or wheel wells with undercoat or paint?
Thanks much for all responses.
) and he said he had done fiberglass boats, pine, metal, brick, etc. and it worked well. He had not done vinyl as in vinyl siding. I asked if he had done cars, specifically Corvettes and he had not.
