So, last June my bone stock 63 coupe started shuddering right under my backside after the car had been driven a while; the right rear brake (all stock drum on all 4 corners) was heating up (like 35*-40* different than the left rear) and you can smell the hot linings. Once the shuddering starts it continues even when not braking and once the car sits a while is fine again.
So - I replaced the wheel cylinders, all parking brake cables (they were seized but not the issue), rubber hoses in the back and bought new high-end drums (all around as mine were getting thin) and replaced all of the shoes. Problem remains (see picture of rear drums) right rear is tinted gold. I even put washers between the master cylinder and power brake booster to ensure the brakes weren't dragging (which I think would affect both sides).
So, then I think maybe I have a bad bearing heating things up and this turns into a complete rear suspension rebuild, which was due anyway.
* Trailing arms (including NEW spindles) and half-shafts rebuilt by Van Steel
* Replaced 63 inner body cushions, snubber, sombrero, NOS leaf spring cushions and strut rod bushings.
* Driveshaft balanced and Spicer U-joints installed
* New shocks
* I didn't mess with the posi differential as stub yoke play was 0.025" on the left and 0.027" on the right - which isn't much and I don't see how that woul cause this issue anyway.
Eight months go by after this work (due to health issues) and I can finally start driving the cara again.
It appears I have the SAME issue now, very frustrating., just got back from a drive and everything was glass-smooth for 15 minutes. After some traffic the shuddering starts and the hot brake lining smell - I get home and the left side hub is 85* and the right side is 117*.
I'm stymied, I can replace (once again) all the brake parts on each end of the rear axle, but now I'm wondering if a master cylinder or booster issue may be the culprit. I'm seldom completely stumped on an issue but this one has done it.
* New shocks
