1968 4 speed - NCRS Discussion Boards
1968 4 speed
  • Todd R.
    Infrequent User
    • January 13, 2019
    • 7
    1968 4 speed
  • Mark M.
    • October 21, 2008
    • 333
    Re: 1968 4 speed
    Todd I would first check the shifter and linkage for issues. You would have to get under the trany and check linkage and shifter first for something loose or out of adjustment. Having someone moving the shifter may help. Check the linkage brackets bolted to the trany , 4&3 ,2&1 should be pointing up for neutral if it's in reverse. If loose or out of adjustment, it may be sticking in a gear not allowing a change. Disconnecting one linkage rod at a time to see if the bracket is moving all the way to neutral position. Is the shifter original or a hurst? Original uses a piece of flat stock you can make and hurst uses a small rod placed in the shifter bottom to hold shifter in neutral while the linkage is adjusted. It's tight in there and pulling the trany mount to lower it a bit can make a enough difference.
    • Todd R.
      Infrequent User
      • January 13, 2019
      • 7
      • Todd R.
        Infrequent User
        • January 13, 2019
        • 7
        Re: 1968 4 speed
        Mark, Thank you 5 minute Fix. Car sat for ever and as you know they need to be driven. Thanks again!!!
