66: differing widths of the two beads on the upper/rear coupe window channel - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Gary
  • Douglas L.
    • August 31, 2003
    • 299
    Re: 66: differing widths of the two beads on the upper/rear coupe window channel
    Gary,
    I think 66 is the same as 67. The outer bead is larger than the inner.
    • Gary B.
      • February 1, 1997
      • 6979
      Doug,
      Thanks. At first I assumed the two NOS window channels I bought years ago were not sided. So I just grabbed one today and started to install it on the passenger’s side. I only had one of the nub retainers snapped into place and it was getting close to dinner time, so I stopped. Then somewhere in the back of my mind this thin/thick bead issue percolated to the surface. As often happens with random chance, the window channel I grabbed was the driver’s side, based on your clarification about where the thicker bead goes. Hopefully, things go smoother tomorrow.
      A first, the difference in bead width seems somewhat subtle (Unless you know to look for, then it’s pretty obvious. As in your photo.) I wonder how many restored C2 coupe doors have them backwards.
      Gary
      • Gary B.
        • February 1, 1997
        • 6979
