Rears are done. Fronts look like a pain. Not much for easy access to bleeders even with a hoist. Any good suggestion for a one-person pressure bleed? Remove tires? Jack J.
1964 front wheel cylinders bleed
Re: 1964 front wheel cylinders bleed
Yep, remove the wheels. If you trust the bleeders with the check-valve use those. Some tools I use. Made one.
- Top
Literally - just did this job on my 63 yesterday, do remove the tire and you can turn the wheel for more visibility if needed. And a bleeder wrench as show above by Harry is a "must have" tool for the job.- Top
