Distributor shield plastic rivets - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2155
    • December 1, 2005
    • 173
    Re: Distributor shield plastic rivets
    Michael,
    I just restored my shield including removing/reinstalling the plastic shield. Ordered a kit from Paragon that included ground strap & metal rivets, plastic inner shield and plastic rivets. The holes in the new inner shield did not line up so I used my original. I was able to remove the original plastic rivets and used them to practice before installing the new ones. The rivets must be melted to secure them. I used my soldering gun for this. You must be very careful so as not to ruin the rivet. I was able to get one rivet melted down so it was tight against the plastic shield. The other was a wee bit loose as I could rotate the rivet. I was afraid that further heat would ruin the rivet so I simply placed some super glue around the melted head of each rivet. Now they are both tight. If you can, practice a bit with your soldering gun on the old rivets.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Another method I've used is to heat up the end of a long 3/8" bolt with a propane torch and swedge the end of the rivet. The natural indentation of the tip of the bolt acts to help capture and round off the end.
      • Michael G.
        • November 12, 2008
        • 2155
        Thanks guys, I was thinking that heat was the only way to swedge them, so I bought a few to practice on. I like the idea of using a bolt point to form them. The indentation on the point varies bolt-to-bolt and I can select a shape close to the original from the vast supply of bolts that I have.
