Rear Stabilizer links for 98 base Coupe - NCRS Discussion Boards
  • Stephen W.
    • March 1, 2002
    • 301
    Time to replace the rear stabilizer links on my 1998 Coupe. Was told by GM dealer the original links have been changed by GM to a different service replacement. Looking for best replacement to keep links original. Thanks in advance.
    Re: Rear Stabilizer links for 98 base Coupe
    Stephen------
    The original rear stabilizer links for your car were GM #10254908. The current GM replacements are GM #20822934. These may also have been used in PRODUCTION on later C5. I do not know how the 10254908 differs, if at all, in configuration to the 20822934. However, I strongly suspect that the later part represents an improvement over the former. I think I'd use the later.
    • John S.
      • June 15, 2015
      • 505
      Stephen, a few years back I replaced all of the sway bar links on a friends ‘99 coupe. While I was very impressed with the lightweight composite design of the originals, they were completely worn out on his car at about 60k miles. I believe the rears were worse than the fronts, but all four were clearly in need of replacement.
      At the time I had read about an improved GM design that I believe was used on the C6’s, perhaps that it the GM replacement Joe is referring to. My friend chose to go with Moog P/N K750126, much heavier than the originals, they are greasable and will probably last the life of his car. While I wouldn’t consider them the best choice for originality or judging, my friend said that his car has never handled better.
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
        John-------
        The GM #20822934 is the rear stabilizer bar link applicable to C6 Corvettes.
        • Stephen W.
          • March 1, 2002
          • 301
          • Michael M.
            Infrequent User
            • August 29, 2012
            • 20
            • Michael M.
              Infrequent User
              • August 29, 2012
              • 20
