When I disassembled by '64 engine (L75), there was no lower dipstick tube installed, only the upper. I'm doing reassembly now and the fit is very loose in the block. I did some reading, and realized that there is supposed to be lower tube installed first. My understanding was that you drop the lower tube in the hole in the block, then install the upper tube with the special tool.
Sounds easy, but there is no way the upper tube fits inside the lower tube, or vis versa. I purchased a lower tube first. Drops in the hole in the block with no problem, flange at the top stops it from dropping all the way through the hole. My exisiting upper tube also fit in the hole in the block - very loosely - so my hope was it would fit inside the lower tube and expand things somehow to a tight fit. No dice. Not even close. So I bought a new upper tube. This would have a tight interference fit with the hole in the block, and the put-it-in-the-freezer-first advice makes total sense if the lower tube is abandoned. But I don't see any way to install them both using the hole in the block. What am I missing? How does the lower tube get installed?
Thanks!
Thanks!
