Questions about 64-66 turn signal switch actuating plate & cancelling cam
Re: Questions about 64-66 turn signal switch actuating plate & cancelling cam
Gary,
You are right about the old grease on there. Clean it ALL off and use a good synthetic multi purpose lube and you won't ever have to grease it again. I don't like to use white lithium on anything anymore, there is much better longer lasting stuff available these days that won't dry out. The foam pieces IIRC are insulators and don't get greased. Good luck. Dan- Top
