63 fuel filler cap - NCRS Discussion Boards
63 fuel filler cap
  • Gerald J.
    Infrequent User
    • January 22, 2018
    • 22
    63 fuel filler cap
    Rumor has it that the gas cap is yet another 63 only part. True? If so, what is different/special about it.
    Jerry
  • James W.
    • December 1, 1990
    • 2640
    Re: 63 fuel filler cap
    Yes it is. The '63 fuel cap has a smaller vent hole than the 1964 and up caps. See the attached pictures. This is a spare I have that I was going to restore this winter.
    James
    Jerry
    • Larry M.
      • January 1, 1992
      • 2688
      It is no rumor........it is a fact.
      I tired to answer you on the other forum.
      Larry
      • Joe R.
        • July 31, 1976
        • 4547
        This is a comparison pic.
        Note the two on the left has a much larger hole!
        • Larry M.
          • January 1, 1992
          • 2688
          https://www.forums.ncrs.org/showthre...=1963+fuel+cap
          Search this forum using the terms: "1963 fuel cap" for many more threads on this subject.
          Larry
          • Arland D.
            Moderator
            • July 31, 1980
            • 415
            Joe,
            Is it just the pictures or do the two on the left have a small metal 'collar' around the hole and a slight shoulder while the 63 has a simple hole on a smooth sloped surface? Is there an early and a late version? :-)
            • Joe R.
              • July 31, 1976
              • 4547
              Yes, the two later model 64 and up have some sleeve or stamped object in the vent hole. And yes, there was an early and late 63 but it was an internal baffle having to do with venting.
              JR
              • Tom R.
                • June 30, 1993
                • 4081
                Originally posted by Arland Dower (3734)
                Joe,
                To be precise...
                The 1st design fuel cap was used from the beginning of 1963 production and as late as VIN 20,000. The underside center of the cap has a 1/16" hole and vents openly to the atmosphere.
                A 2nd design gas cap was used for the remainder of 1963 and through the end of 1964 production. Centered on its underside is a flanged hole and series of internal valves that release pressure to the atmosphere.
                Tom Russo
                78 SA NCRS 5 Star Bowtie
                78 Pace Car L82 M21
                00 MY/TR/Conv
