Body On Engine/Transmission/Shifter Installation - NCRS Discussion Boards
  • Mark H.
    • July 31, 1998
    • 384
    Planning to install the engine/transmission as a unit. It sure would be easier to sort/install the shifter as well before putting it back into the car. Have searched to no avail - is there room to install the shifter with the engine and transmission (4-speed)? Thanks.
  • Jim L.
    • September 30, 1979
    • 1805
    Re: Body On Engine/Transmission/Shifter Installation
    If your shifter is a Hurst with the removable stick, it could probably be on the transmission when you set engine/trans in place. For any shifter with a permanently attached stick, my opinion is that you're better off installing it after the engine/trans are in.
    But, full disclosure, I've never tried it; I'm speculating based on experience.
    If you try installing engine/trans with shifter, what's the worst that could happen? You'd have to pull the engine back out, remove the shifter, and re-install. Let us know how well that goes!
