For 1969 was the TR on the valve cover bolts the large or the small one?
1969 427 Valve Cover Bolts
- Top
Re: 1969 427 Valve Cover Bolts
Terry,
I understand the judging manual says that that change occured I believe in July of 69 but it is in the 67 AIM as well. So if they had it in 67 I would think they carried it forward in 68 & 69. After all why would they implement it and then remove and re-implement it. It does not sound right, I would think they would implement the change and carry it forward until it was no longer needed.- Top
I am with you, and seeking evidence.Terry,
I understand the judging manual says that that change occured I believe in July of 69 but it is in the 67 AIM as well. So if they had it in 67 I would think they carried it forward in 68 & 69. After all why would they implement it and then remove and re-implement it. It does not sound right, I would think they would implement the change and carry it forward until it was no longer needed.Terry- Top
The 69 I spoke of had what seems to be all it's original vc bolts but one was missing. The original covers were found and I restored and installed them recently. Next week I should be able to check it again and as I remember, all but the one replaced bolt had small TR on them. This is a July car.- Top
