Too Hot to Trot? - NCRS Discussion Boards
Too Hot to Trot?
  • Jack W.
    • August 31, 1995
    • 126
    Too Hot to Trot?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: Too Hot to Trot?
    Jack,
    Key ON, temp sensor wire on engine sensor to ground, should peg the meter.
    Key OFF, check meter/gauge connections, in particular the studs for the connector and the other stud nut for the ground to the gauge. Also the small screws for the gauge pod. All meter grounds come from cluster backplate screws.
    Sometimes backing off and a retightening will correct a bad connection.
    At ambient, the sensor should read around 300 to 500 ohms but varies a lot based on manufacturer. Hot(180*) should be in the 100 or so range. I have a long post in here somewhere showing extensive sensor testing.
    Here....
    https://www.forums.ncrs.org/showthre...ht=sensor+test
    Rich
    • Jack W.
      • August 31, 1995
      • 126
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Good. Glad it was simple. Corvettes and Grounds always a issue.
