1969 Engine Harness connection to Transistorized Ignition K66 - NCRS Discussion Boards
  • Peter S.
    • March 28, 2012
    • 327
    All,
    I'm installing a new engine harness (lectric Limited) in my 1969 L46 w/ AC and transistorized ignition. I'm having a problem reading the AIM and how I am supposed to modify the new engine harness to connect to the K66 harness.
    Below is a picture below with the two-wire coil connection on the new engine harness, and the existing connection that ties into the K66 harness. Thoughts on how to proceed?
  • Peter S.
    • March 28, 2012
    • 327
    Re: 1969 Engine Harness connection to Transistorized Ignition K66
    I found this slightly vintage, very informative thread:
    https://www.forums.ncrs.org/showthre...engine+harness
    Looks like I need to modify the wire, but anyone have a source for this bulkhead? Lectric Limited specifically states they do not sell individual components, except in their repair kits, which this part is not.
    • Bill B.
      • August 1, 2016
      • 303
      Hi Peter,
      Looks like you are missing two things for conversion:
      1. The circled female terminal and its plastic cover shell (P/N 5601 - $10)
      2. The pink extension wire that connects to the steering column connector inside and exits thru the firewall. (P/N 5378 - $16)
      Fortunately, Paragon Reproductions offers (as I assume others) these items to be purchased separately. Paragon P/Ns referenced above.
      I had to buy these items as well, since I also purchased a Lectric Limited Harness at Carlisle and it did noy have these two required items for conversion.
      Bill Bertelli
      Northeast and Carolinas Chapters Member
      '70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain
      • Peter S.
        • March 28, 2012
        • 327
        Originally posted by William Bertelli (62632)
        Hi Peter,
        That's perfect, thank you Bill! I do already have the pink extension wire as it's still in the car, just needed that little connector to modify the new wiring harness.
        Thank you very much for the help.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Wow I remember that thread. I learned a lot about C3 TI wiring on that one!
          • Peter S.
            • March 28, 2012
            • 327
            Fantastic info there Richard, thank you very much.
