I am starting a rebuild of my original 1965 suction throttle valve. I have the '65 Shop Manual which has a detailed procedure. Does anyone have tips or comments to add to that procedure? Thanks, Don H.
1965 Suction Throttle Valve
Re: 1965 Suction Throttle Valve
Don, to start, assume the adjustments (screws are correct) for your altitude. Yes, it is spring loaded, so take it apart slowly.
I took mine apart, cleaned it with alcohol, let it dry and installed a new diaphragm. Reassembled the unit. I believed it had a hole in it. I also rebuilt and/or replaced the compressor and expansion valve. Installed R12 and it been fine for 5 years.
Good Luck
- Top
I finished mine and installed it, so far it has held vacuum and took a charge. The '65 Corvette Shop Manual Supplement has good drawings and procedure. I found the mating surfaces (where the two halves join) of my valve were bad. I used longer screws to align when assembling and did depress the piston as it said. Good luck, Don H.Attached Files- Top
Don,
Where did you source your rebuild kit?
James
I finished mine and installed it, so far it has held vacuum and took a charge. The '65 Corvette Shop Manual Supplement has good drawings and procedure. I found the mating surfaces (where the two halves join) of my valve were bad. I used longer screws to align when assembling and did depress the piston as it said. Good luck, Don H.- Top
keep us posted on how well it goes. I have one to do when I get back home from the convention.- Top
- Top
Hi, I just charged my 1966 AC with r12 (after flushing and rebuilding STV) and it only took 2# 7oz to get a clear stream on the drier window? Is this unusual? I'm getting ~44' air at the vents, which is really nice! Gauge pressures are: LP 34 (no vacuum attached to AVR), HP 185 (OAT ~75')
- Top
Robert:
Capacity of your system is 3 lbs 4 oz.......or 52 oz. The sight glass should clear up about 12 oz before this point.......or 40 oz. You saw this at 2 lbs 7 oz or 39 oz. So I would say you are "right on the money" as far as total refrigerant charge.
Your LO side pressure is a bit high, and I believe you can adjust the STV to get it down to 32 psig. Or perhaps just hooking up the vacuum will also accomplish this. That will improve cooling in the cabin by at least 2-3 degree F. The HI pressure is just about ideal for summer temperatures.
Congratulations.
Larry- Top
Do people use an expansion valve screen on newer (four seasons I think) replacement expansion valves? There isn't enough length (about 3/8" shorter) to fit an original screen (GM 15-512), but I guess the top collar could be removed to fit in the available space?
- Top
Short answer is NO.Do people use an expansion valve screen on newer (four seasons I think) replacement expansion valves? There isn't enough length (about 3/8" shorter) to fit an original screen (GM 15-512), but I guess the top collar could be removed to fit in the available space?
Larry- Top
As an update: My rebuilt STV was weeping a bit of oil, so I vented (I have a Robinair RG3 recovery machine) and rebuilt it again. It looked like the diaphragm was slightly pinched. I reinstalled, recharged and now have (vacuum disconnected) LP: 33psi HP: 233psi vent temp 41' (OAT 73' 80% humidity). I charged with 3# 4oz this time, but it was too hot in the garage, even with the turbo fan on high, so I'll recheck pressures and sight glass again tomorrow. After charging, It was actually ICE COLD in the car when I shut it down. Unbelievably, I now have parts from 3 different STVs, an original expansion valve I'll get rebuilt (its too dirty to do myself), a partial r12 tank, refrigerant recovery equipment, and enough spare parts to last a very, very long time! I am having fun though...
- Top
