95 vette heater, AC bypass valve - NCRS Discussion Boards
  • Joe C.
    • April 30, 2001
    • 126
    does any one have a photo of the heater/ac bypass valve hooked up under right valve cover of a 95 vette? i have replaced my ac programer as well as ac module and i still have ac coming out of defroster, i purchased a new one but i'm not sure my old one might not be intalled correctly. thanks for any help.
  • David H.
    • June 30, 2001
    • 1485
    Re: 95 vette heater, AC bypass valve
    Joe
    Defroster is default position for HVAC air flow. One cause for defroster only is a vacuum leak. You might check under hood HVAC controls vacuum supply lines for leaks (passenger side). You noted replacement of "ac module" - was this the under dash controller that has multiple vacuum lines running into it? Later C4 has a vacuum controller utilizing rubber nipples connecting lines to controller. These rubber nipples can internally collapse blocking vacuum control. (Earlier C4 connection was hard plastic).
    Dave
    • Ed N.
      • May 16, 2010
      • 990
      Is this what you are looking for?
      Here it is installed. The front nose of the valve goes to the front as you can see. The others are self explanatory.
      Ed Nieves
      NCRS #51799
      • Joe C.
        • April 30, 2001
        • 126
        I replaced ac module under dash and checked hoses and nipples , everything looked ok. I saw on rt side under valve cover a bypass set up, I wasn't sure if it is connected correctly, thats why I was hoping someone had a pic of it, so I could check my connection.
        • Joe C.
          • April 30, 2001
          • 126
          thanks for pic, yes. thanks again.
          • Joe C.
            • April 30, 2001
            • 126
            just to wrap up thread. checked hoses under dash, and fixed problem had small leak in that hose. replaced and everything now works fine. ac is coming out dash vents. whew what a job. thanks for all your help in this.
            • Ed N.
              • May 16, 2010
              • 990
              Glad it worked out for you.
              Ed Nieves
              NCRS #51799
