Hi all,
I have a S-W electric fuel pump mounted on the frame of the '57 race car I'm restoring to as-raced, but nothing connected yet.
The mechanical pump speed, since it runs off the cam, varies according to rpm, but the S-W would have constant speed and constant pressure. The fuel bowl float closes the pin that lets in fuel, but what about the pressure on the line? Would that constant pressure make the line prone to leaks?
I have a S-W fuel pressure gauge mounted in the dash and a sender is coming any day, but would using two pumps make the pressure too high since there is no return line?
If the S-W electric pump conked out, could the mechanical continue working or is there some restriction in the S-W?
And if the mechanical conked out, is there some restriction in the mechanical that would impede flow from the S-W?
Bob
Bob
