66 Valve Stem Caps>Dill 627 -Where to purchase them? - NCRS Discussion Boards
  • Larry E.
    • 1652
    AFAIK the below are the correct Valve Stem Caps that came with the 66 Corvettes.
    The SCHRADER caps of the configuration used in the mid-60s are not easy to find; but the DILL caps, specifically the DILL 627 Valve Cap embossed DILL 627, are readily available.
    I could not find (Maybe missed it) any of the above for sale in the latest "Driveline". Who would be the go to
    member/vender that has these for sale? Let me know on this thread or PM me>Thanks in Advance>Larry
    Larry
    LT1 in a 1LE -- One of 134
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 66 Valve Stem Caps>Dill 627 -Where to purchase them?
    $4.00 at LIC.
    Leif
    • Bob B.
      • March 1, 2003
      • 831
      Dill 626 caps were first used on Corvettes in 1960. Metal caps were used before that. Early 60's DILL 627's used bigger font, had a rounded nub in the middle, and are slightly taller. These are scarce as hen's teeth and I have seen them only on Bowtie cars. The one in the attached pic is the only one I have and I found it in a junk box of random caps.
      Late '60's through the present (my JD mower has them) use the smaller font with depression in the nub and are a little shorter. I'm not exactly sure when the cutoff was between the older and newer styles in the mid-60's.
      Schrader caps are usually also numbered. What Schrader cap number is the hard one to find for Midyears?
      • Larry E.
        • 1652
        Thanks Bob for nice report. I did buy some from a member which I assume are not "THE ORIGINALS" AS SHOWN.(Far left)
        I hope I am not wrong assuming that they will pass judging. Picture below is the original type "Schrader Type Caps"-Larry
        Larry
        • John F.
          • March 23, 2008
          • 2395
          I find mine at the old time tire shops around town!
          • Leif A.
            • August 31, 1997
            • 3607
            It appears that the good Doctor has some very nice looking caps. $7.50
            Leif
              • 15573
              Just a SWAG on my part, but my guess is that Schrader number is a mold number since they would have been making these by the millions. If so that number is of no significance.
              • Bob B.
                • March 1, 2003
                • 831
                Oops! I see I put DILL 626. No such thing. It is DILL 627.
                • John D.
                  • December 1, 1979
                  • 5507
                  A friend of mine was the manager of a large tire shop. They did a lot of recaps for the big rigs also.
                  "Red" had buckets of old valve stem caps. So I asked him if I could look thru them to pick out the Dills with the large font.
                  I had a restaurant then and Red came in most every night, He said take two buckets home and pick up what I want etc.
                  I found a ton of the Dills with the large font in the old days.
                  • Ed S.
                    • August 6, 2014
                    • 1377
                    So.... under the definition of learning and understanding what is considered acceptable for judging - these valve stem caps, they are repro's --- never having seen an original, I am curious - would these caps pass judging? Are they "good enough" ...... or so good as they would not earn a point deduction?
                    Ed
                    • Leif A.
                      • August 31, 1997
                      • 3607
                      Ed,
                      Having had mine judged four times, I don't remember getting a point deduct for the reproduction caps...maybe a "dot" and a mention but that's about it.
                      Leif
                      • Ed S.
                        • August 6, 2014
                        • 1377
                        Ed,
                        Good to know - thanks Leif.
                        Ed
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          Terry, likely the number is the cavity number of a a very large multi cavity mold, ....only way to make thousands a day.
                            • 15573
                            Ron
                            That's what I was trying to get at. I just didn't know the correct terms to use. Thanks for the clarification.
                            • Thomas N.
                              • July 31, 2002
                              • 387
                              Enclosed is a box of NOS caps. I took a picture to show the taller earlier caps.
                              NCRS New England Chapter Chairman 2022, 2024
                              N E Regional Chairman 2024
                              1967 Corvette Convertible Under Restoration
                              1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
