67 Headlight door switch
Re: 67 Headlight door switch
Was the connector corroded? Have you tried to connect/unconnect several times? Remove switch from dash and try spraying switch with contact cleaner, cycling the switch several times.
Refer to an earlier thread on the subject located below in "similiar threads" There is a description of switch disassembly under "Robert Margolies"- Top
- Top
Also listed under "Headlight" in the Sticky Main page....
https://www.forums.ncrs.org/attachme...3&d=1597503489- Top
