Wiper transmission arms attachment to wiper motor shaft - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Gary
  • Donald O.
    • May 31, 1990
    • 1580
    Re: Wiper transmission arms attachment to wiper motor shaft
    Originally posted by Gary Beaupre (28818)
    motor rotation. Actually, a video of that arm to shaft connection with the wipers turned on would be fascinating to view if anyone has such a video.
    Gary
    It may be, but it works. I replaced the original one on 67 after 49 years and 85k miles of service, only because I had it all apart to remove the WW assembly and have it restored.
    Don
    • Gary B.
      • February 1, 1997
      • 6979
      Don,
      Does the spacer/washer just sort of loop around and in between the two transmission rods, near the connection axis? The ID of the spacer is about 4x larger than the stubby shaft that the rods connect to.
      Gary
      • Donald O.
        • May 31, 1990
        • 1580
        Don't try to wrap it or loop it. Just put it on like a washer and be amazed at how well it does its job.
        I thought my original was all stretched out, but after talking with the late John Hinckley, he told me that that is how it is assembled.
        Don
        • Larry E.
          • 1652
          Gary
          I could be wrong but if it's the part I am thinking about it did not appear till the Mid-66 C2 production. My very early 66 Coupe
          (Early Sept. of 65) did not have this on it. Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Stephen L.
            • May 31, 1984
            • 3148
            Here is a photo of the rubber washer installed on a 67. If you have access to the transmission system as shown in the photo, I'd recommend welding the short arms to the transmission studs. They were "staked" on from the factory and become loose from use. Welding eliminates the "slop" in this joint.
            • Gary B.
              • February 1, 1997
              • 6979
              Larry,
              The same part number for the spacer, GM#3764098, appears in the 63 thru 67 AIMs, so we may be talking about different parts.
              Gary
              • Gary B.
                • February 1, 1997
                • 6979
                • Stephen L.
                  • May 31, 1984
                  • 3148
                  Gary, if you have the dash out as in my picture, you could just remove the wiper assemblies from the car and take them to a local welder. Welding them sure tighten up the "action" of the wipers in my car......
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    Stephen,
                    Fortunately, the dash is not out. And I hope not going to come out in my lifetime!
                    Gary
                    • Larry E.
                      • 1652
                      Larry,
                      Gary
                      . Looks like
                      I was thinking of those black plastic covers. Larry
                      Larry
                      • Bob W.
                        • December 1, 1977
                        • 799
                        Gary, Looking at the photos on Corvette Centrals web sight , you might be able to find something close at Lowes or Home Depot.
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          • Timothy B.
                            • April 30, 1983
                            • 5177
                            Gary,
                            IMO, it's a cheap reproduction part! I don't think I've ever seen a original.
                            My thinking is the ID of the rubber washer you have fits over the OD of the brass bushing pressed on the drivers side transmission arm. Do you have that measurement?
                            Years ago we discussed this part and John Hinckley mentioned it's a hard fiber sort of washer. My 67 had never been touched and I could not find any remnants of the washer.
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              That fibrous/hard rubber spacer was on all midyear wiper
