Water pump - NCRS Discussion Boards
Water pump
  • Bill M.
    • 1317
    Water pump
  • Kenneth B.
    • August 31, 1984
    • 2084
    Re: Water pump
    How in the world did you snap a CI water pump in half rebuilding it. Inquiring minds want to know.
    • Jimmy B.
      • July 31, 1980
      • 584
      Re: Water pump
      don't feel bad years ago I was rebuilding mine and broke my big right toe....
      • Bill M.
        • 1317
        Re: Water pump
        When pressing out the shaft I did not support the body I just allowed the inlet and outlet to do the supporting. I should have added a little heat as well
        Then my 1989 tv vcr died on me so I went inside.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Re: Water pump
          Yes I broke Frank's that I dug up to replace his incorrect SHP pump with a Base pump.Plus my bearing driver 7/8" socket was too big in the OD. 1/8" down on the press..... SNAP!
          BTW, Step 4 below talks about supporting the body, here....
          Corvette Water Pump Rebuild at Zip. A simple call will get you every piece you will need to do a thorough and correct rebuilding job on your existing pump. We accomplished this entire rebuild in one afternoon without any complications. Now with all of this in mind, let’s get that pump rebuilt and keep your numbers matching.
          • Michael J.
            • January 27, 2009
            • 7073
            Re: Water pump
            Do you need a 326 or a 175?
              Re: Water pump
              Originally posted by Bill McMorrow (15609)
              Well anyone rebuilding their water pump remember to support it properly. I just snapped mine in half. I guess I’ll be looking for a 326 B 7 Ughhh
              Bill------
              If one attempts to press out the bearing/shaft assembly while supporting the pump on its "legs" I can virtually guarantee that one will break the pump body. The pump MUST be supported on its body (i.e. the backing plate seal surface).
              • Joe R.
                • July 31, 1976
                • 4547
                Re: Water pump
                Just another example of why one needs to send their water pump to Bill Mock for a rebuild!
                JR
                • Timothy B.
                  • April 30, 1983
                  • 5177
                  Re: Water pump
                  I too am in the hard lesson group when it comes to water pump overhaul. Then when it broke I looked at it and thought I KNEW THAT WHAT THE HECK WAS I THINKING!!
                  Luckily the pump was a 608.
                  • Bill M.
                    • 1317
                    Re: Water pump
                    Mike a 326 pump
                    • Bill M.
                      • 1317
                        Re: Water pump
                        Timothy------
                        That's EXACTLY what happened to me. I learned the hard way, too, and immediately after the pump body broke, I asked myself why I didn't anticipate that would occur. Mine was a 608 pump, too, but it was the original pump installed on my 1969 300/350. Since it was dear to me, I had it weld-repaired by a real expert. It was expensive but I saved the pump. Later, I was even able to purchase an identical NOS pump from Bill Mock with the exact same date as my original pump. Once again, VERY expensive but it was an EXTREMELY rare find. I have complete confidence in the original, repaired casting, though. I even rebuilt it using a special stainless steel seal assembly with Viton bellows obtained from an aerospace supplier. It cost me over $50 more than 25 years ago. By the way, most automotive waterpump seals have buna-n or neoprene bellows. These do not have the temperature or chemical resistance of Viton.
                        • Bill M.
                          • 1317
                          Re: Water pump
                          Joe L the pump was on the car in 88 when I bought it not sure if it is original dates B 14 7. I deal with welders in my work let me see if any will repair thanks
                          • Frank D.
                            • December 27, 2007
                            • 2703
                            Re: Water pump
                            https://www.corvettemagazine.com/195...-pump-rebuild/
                            Ugh! I remember that - was sorta fun though running around rural Florida after dark in your late model Corvette, raiding your friend's incredible stash of C2 goodies for the right pump!
                            • Mike E.
                              • February 28, 1975
                              • 5134
                              Re: Water pump
                              Snapped a 3782609 pump the same way about 15 years ago. That's about a $500 mistake today. Pre-You Tube.
