Water pump - NCRS Discussion Boards
Water pump
  • Frank D.
    • December 27, 2007
    • 2703
    Re: Water pump
    Easily $500 - I paid that 6 years ago for a Bill Mock restored 609...
    • Bill M.
      • 1317
      Re: Water pump
      Dam thanks for the good news.
        #18
        Re: Water pump
        Bill------.
        If this is what you're referring to, it's the '609' casting that's expensive. The '608' is much easier to find and much less expensive.
        • Mike E.
          • February 28, 1975
          • 5134
          #19
          Re: Water pump
          Bill------.
          You’re right. absolutely no comparison in rarity/price.
          • Timothy B.
            • April 30, 1983
            • 5177
            #20
            Re: Water pump
            But the lesson was the same.... :-)
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              #21
              Re: Water pump
              Originally posted by Frank Dreano (48332)
              Ugh! I remember that - was sorta fun though running around rural Florida after dark in your late model Corvette, raiding your friend's incredible stash of C2 goodies for the right pump!
              I'll never forget that night.
              Crazy thing is, if you recall, I bought a rebuilt 608 from my vendor, and THAT failed too! I ran the car up the road, came back, and it was making noises, leaking, and the doggone bearing had about 1/4" of fan tip play in it.
              I gave up on vendor rebuilt pumps. I do them myself. Getting burned is ugly.
              Snapped a 3782609 pump the same way about 15 years ago. That's about a $500 mistake today. Pre-You Tube.
              So, when I restored a 61 fuelie, I decided to go for the fine new reproduction 609. I now have it on the wall as garage art.....
              Long post all about it here....
              https://www.forums.ncrs.org/showthre...AK&mode=hybrid
              Rich
              • Bill M.
                • 1317
                #22
                Re: Water pump
                Rick pretty sure I remember reading about your adventure leaking right through the body. Makes a good 50 yard target.
                • Domenic T.
                  • January 29, 2010
                  • 2452
                  #23
                  Re: Water pump
                  Just a tid bit, but when I did my pump using their measurments for the pulley flange, I found it to be off a bit over 1/16 of an inch and had to align it to get the belts really good.
                  Dom
                    #24
                    Re: Water pump
                    Dom
                    Dom------
                    There were two slightly different hub spacings for small block water pumps used in part of the C2 era. If rebuilding a pump, the best thing to do is to measure the hub spacing of the pump being removed and set the hub spacing of the rebuilt pump to the same.
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      #25
                      Re: Water pump
                      Joe, that's good advice. I did what you suggested , belts looked good before, but I used a straight edge to find the error.
                      Dom
