My 63 always started and ran perfectly. I pulled it into the garage and parked it for a month or so. Yesterday was a beautiful day in the Pacific Northwest so I decided to go for a drive. After cranking for awhile, it would not start ( it's an L84 Fuelie ). It has gas so I then checked for spark. I pulled the coil wire from the dist. and placed it 1/4'' from a ground point. I cranked the engine and found no spark. Did my 091 coil die while it sat idle? I turned the ignition switch to the on position and checked voltage at the + terminal of the coil and had full battery power. It also had full battery power at the - terminal. Is that correct? What other tests could I perform to pinpoint the problem? Suggestions please.
Another No Start Situation
Re: Another No Start Situation
You have power to the primary winding of the coil but no spark from the secondary winding. This could be a bad coil, points, condenser or wiring between these three parts.
Check the dwell with the engine cranking; adjust for 30 degrees. Zero or infinite dwell indicates a problem in the primary circuit (points, condenser, related wiring). Make sure the ground wire for the breaker plate is secure.
Test the coil by checking resistance for the primary and secondary windings. Primary: Measure resistance between the small + and - terminals. Secondary: Measure resistance between the small + and the connector for the lead that goes to the distributor cap. Specs are in your service manual.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
The test you did shows there is power to the ignition but it did not indicate whether or not the points are opening and closing.My 63 always started and ran perfectly. I pulled it into the garage and parked it for a month or so. Yesterday was a beautiful day in the Pacific Northwest so I decided to go for a drive. After cranking for awhile, it would not start ( it's an L84 Fuelie ). It has gas so I then checked for spark. I pulled the coil wire from the dist. and placed it 1/4'' from a ground point. I cranked the engine and found no spark. Did my 091 coil die while it sat idle? I turned the ignition switch to the on position and checked voltage at the + terminal of the coil and had full battery power. It also had full battery power at the - terminal. Is that correct? What other tests could I perform to pinpoint the problem? Suggestions please.
Mark's suggestion to connect a dwell meter and crank the engine is a good way to test the points function.
If you don't have a dwell meter, touch a test light to the (-) coil terminal, ground the lead from the test light, and crank the engine. The light should blink in time with points activity.
If you can confirm the points are working, then you might try substituting a known-good coil and attempt starting the engine.- Top
I should confess that I switched to a Pertronics unit about 15 years ago so no points involved. My research of past threads told me that The positive post of the coil should have 12 volts but the negative post should be 9 volts with the ignition switch in the ON position. Is that correct? I have 12+ volts at both posts.- Top
Didn't make any difference. Still no start or spark.- Top
Only sorta and then only maybe.I should confess that I switched to a Pertronics unit about 15 years ago so no points involved. My research of past threads told me that The positive post of the coil should have 12 volts but the negative post should be 9 volts with the ignition switch in the ON position. Is that correct? I have 12+ volts at both posts.
Points or Pertronix, your test light on coil (-) should still flash while the engine is cranking.
With a Pertronix ignition, it's anybody's guess what the (-) terminal should show when the engine is not rotating. It depends entirely on the design of the Pertronix.
As to a coil, go to NAPA and pick up an Echlin IC-12.- Top
[QUOTE=Jim Lockwood (2750);901415]Only sorta and then only maybe.
I guess I already performed the test light test when I hooked up my induction timing light and got no flashes. Thanks for all the suggestions.- Top
No. Your timing light just told you that the ignition system as a whole was inoperative but not specifically what has failed.I guess I already performed the test light test when I hooked up my induction timing light and got no flashes. Thanks for all the suggestions.
If you put a test light on the coil (-) and the light glows steady and never flashes while cranking, your Pertronix is FUBAR.
If the test light does flash and yet you have no spark, the coil could be bad.- Top
Well, I guess my Pertronix went FUBAR. The test light seemed to get dim but did not flash. It's decision time. Do I go back to points or get a new Pertronix unit?No. Your timing light just told you that the ignition system as a whole was inoperative but not specifically what has failed.
Well, your call.
Lots of people swear by Pertronix systems. I've had reason to swear at them.
The only two Pertronix experiences I've had ended badly. Oddly, and not that there is a connection, both were on fuelies. Go figgur.
I've always run points, even in the two track cars of my bride and myself. They have performed flawlessly for me.
Too, points ignition generally will fail soft.... that is you sense degradation before a compleat failure happens. Electronics, which generally should be more reliable than a mechanical triggering mechanism (if it's well engineered) tends to fail without warning. I appreciate that little bit of a "heads up" warning points offer and since they seldom require maintenance, I've stuck with them.
But it's your call....- Top
