3782609 Water Pump-to-block Sealing Surfaces? - NCRS Discussion Boards
  • Bob S.
    • January 1, 2004
    • 181
    Re: 3782609 Water Pump-to-block Sealing Surfaces?
    Originally posted by Bob Schaefer (41225)
    Hi - I'm curious what you think about the sealing surfaces on this pump and whether they'll affect sealing to the block … I.e. do the surfaces affect usability of the pump? Thanks.&amp;lt;br /&amp;gt;&lt;br /&gt;<br />
    Bob S.
    Bob------
    I think that if you smear the gaskets with an RTV sealer like Ultra Black this will be fine. As a matter of fact, it would probably be OK as-is but I would not want to chance a re-do so I'd use the sealer. You could have the surfaces machined but then you'd have to use thicker gaskets.
    By the way, I do not think that pump backing plate is correct for a '609' pump BUT IT'S THE ONLY ONE I'D USE. PERIOD!
    • Mike E.
      • February 28, 1975
      • 5134
      The dozen and a half or so 609 pumps that I have had over the years had that backing plate, including two bowtie cars, so I would vote for it being correct.
        Mike------
        Note the linear depressions between the bolt holes. I do not think this feature began until well after the '609' pump was out-of-production. However, this is a very important feature. Once-upon-a-time I did some pressure tests using both the earlier type without the depressions and the later with the depressions. I could not get the early type to hold 15 PSI.
        • James G.
          • August 22, 2018
          • 783
          Joe - here is a NOS one without the ribs.
          I picked it up about 15 years ago for less than $10 at a swap meet.
          It sat around for years, ended up trading it to Bill Mock a few years back when I was looking for a 399 for my LT1.
          I think Bill was in shock when I told him I had this pump.
          I had no idea how scarce they are until speaking to Bill.
          James A Groome
          1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
          1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
          My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
          Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
          • Frank D.
            • December 27, 2007
            • 2703
            Here is my Bill Mock restored 609 pump - it was the best of three he had for sale, as far as corrodded/pitted flange connections, those might seal, however I've used JB-Weld (regular not the QiK) to make repairs on such things such as my 63's thermostat housing flange and it lasted for 1/2 decade leak and problem free. I'm sure my approach will scandalize some here
            • Bob S.
              • January 1, 2004
              • 181
