Hi guys! Several weeks ago I posted a thread about the problem I was having with my '67 Corvette. With the engine running my garage door opener would not work. I had to step about 10 feet away for it to do so. I thought the problem was with my alternator. I unplugged it and the opener worked. At that time I was also replacing the radio with one that has bluetooth. Well, the radio would not work with the engine running either. I have radio suppression ignition wires and full ignition shielding. I tried various things including replacing the alternator which was giving me trouble anyway. Nothing worked. I talked with a friend of mine who talked with a restorer in Jackson, Tennessee who came up with the solution. First let me say that I am not any kind of electronic or electrical genius. I can't explain the why with the solution only what worked. My understanding was that my car has some kind of problem referred to as radio frequency interference or feedback. I don't know if all cars have it but mine does. The solution was to run a wire from the hot lead going into the radio to the fuse box. I do not have power windows so I was able to plug into one of the two leads there. Both leads worked to make the radio play and the garage door opener operate. I had to use the left lead as when plugged into the right side lead on power windows caused some of the dash lights to come on. Now everything works as it should. I don't know if the new radio had anything to do with it or not. It looks original but sounds far better than any factory radio from back in the day did. I hope this will help someone with their project. Thanks in advance for your input.
Brooks Glover Jr. (2141)
