AC Delco R59 Replacement Battery - NCRS Discussion Boards
  • Kevin O.
    Infrequent User
    • October 17, 2011
    • 6
    Does anyone have recommendations on where to order a replacement R59 battery? I need to replace mine on my 67. My current one was purchased from Restoration Battery ~10 years ago and I hear they are no longer in business. Thanks...
  • Jaime G.
    • April 1, 1988
    • 480
    Re: AC Delco R59 Replacement Battery
    try Battery Central
    • Kevin O.
      Infrequent User
      • October 17, 2011
      • 6
      Originally posted by Jaime Gesundheit (12617)
      try Battery Central
      will do, thanks.
      • Eugene Z.
        Infrequent User
        • June 30, 1991
        • 3
        Turbo Start Batteries now have a classic series and they have the R59 in stock
        • Kevin O.
          Infrequent User
          • October 17, 2011
          • 6
          Thanks, will check them out...
          • Dereck S.
            • July 30, 2008
            • 244
            Jim's Battery Inc.
            Youngstown. OH
            1-800-426-7580
            You'll likely get Dotti. No website. It used to be called Antique Auto Battery. Make sure you use an AGM charger. I use Batteryminder 2012-AGM charger. I get 12+ years out of the battery. Using the wrong charger can damage the battery.
            • Leif A.
              • August 31, 1997
              • 3607
              The Turbo Start Collectors Series of batteries are a true AGM battery...not a smaller AGM battery inside a repro case. Read the history on this company...pretty stout products.
              12V LTO 1967-1972 GM Collectors Series Lithium Battery BCI Group 59 Length: 10.25 in.Width: 6.75 in.Height: 9.00 in. Weight Lbs. – 10 Voltage – 12V Energy Wh – 230whCA – 500CA Pb Eq* – 700Ah – 23Ah Pb Eq* – 69 *CA Pb Eq is the equivalent cranking amp output when compared to AGM*Ah Pb Eq is the equivalent amp-hour when
              Leif
              • John D.
                • December 1, 1979
                • 5507
                I have bought two battery's from Jim's Battery of Youngstown, Ohio. Although pricey I will tell you they hold a charge that amazes me.
                John.
                • Kevin O.
                  Infrequent User
                  • October 17, 2011
                  • 6
                  Well, I finally received my R59 replacement from Jim's Battery. Upon unboxing in I found that 3 of the 5 push in caps are very loose with 2 of them easily pulled out with no effort (they are just sitting loosely in their hole). Should I be concerned or just glue them into place so they aren't easily removed or lost? Thanks for any insight...
