�65 electrical grounds
Tags: None
- Top
All grounding screws should be zinc or cadmium plated. Star washers should never be under the bolt - always under the wire-end connector. If you see a ground made to painted metal, the star washer is not likely to cut through it very well, so remove it and scrape off the paint under it.- Top
