Does anyone have a suggestion how to safely remove the gas door emblem on my '84 so I can clean and polish the area around it? I removed the two acorn nuts from behind but the emblem is stuck on with what appears to be foam tape. I don't want to damage the paint or emblem.
Emblem removal
Re: Emblem removal
And soak the double sided tape residual on the door with goo gone.NCRS New England Chapter Chairman 2022, 2024
N E Regional Chairman 2024
1967 Corvette Convertible Under Restoration
1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0- Top
Re: Emblem removal
Dental floss will also work. "Saw" back and forth under the emblem. Slowly as suggested by Mike H.Does anyone have a suggestion how to safely remove the gas door emblem on my '84 so I can clean and polish the area around it? I removed the two acorn nuts from behind but the emblem is stuck on with what appears to be foam tape. I don't want to damage the paint or emblem.Terry- Top
