1967 spare what size is correct / fits ? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 524
    Time to put a spare in my 67 Convertible rally wheels what size tire fits in the spare ? standard rally bolts /
    I have the repro red lines on the ground, heard they do not fit in the spare. THANKS Bob
  • Tom E.
    • June 1, 2019
    • 448
    Re: 1967 spare what size is correct / fits ?
    Bob,
    Are you asking about bias ply or radial sizes? If radial, I have 205/75R15 Redline Radials on my car but they will not fit the tub, after some trial and error I found the 195/75R15 fits snug but it fits. If I get a flat I only need to make it far enough for a repair or a replacement tire.
    Tom
      • 15610
      You heard? Try fitting one of the road tires to the spare tub to find out for sure.
      • Harry S.
        • July 31, 2002
        • 5258
        What you put in the tub does not have to match what is on the other four. I used an off-brand 205/75R/15 made by Matrix and it fits in the tub fine. I use the same tire type in both my C2's. It's only there for an emergency. Just use longer forward bolts as the tire is wider.
        An off-brand tire made today is probably better than the best production tire installed in the 1960's.
        • Eric P.
          • March 1, 1985
          • 131
          Bob,
          I have some tires and wheels that would make for a good spare for your '67 that I would like to sell. If interested send me a private message or call me at 419-583-9944. I am in Ohio.
          Eric Patty
          #8355
          • Kenneth B.
            • August 31, 1984
            • 2084
            Why not just put a origional type spare in the well. Its not like you will be driving on it for a long ways unless you are on a cross country trip
            • Harry S.
              • July 31, 2002
              • 5258
              If it's a posi rear you really should have both rear tires the same size.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Another option is to get another repro redline, mounted, balanced, filled, checked for leaks, then remove the air and it will fit in the tub.
                Carry a 12V air pump so if you ever need the spare.... air it up.
                Rich
                  • 15610
                  Or you could have the typical 10-12/32s" new tread depth shaved down to 3 or 4, which will reduce the inflated OD by at least nearly a half inch.
                  • Kenneth B.
                    • August 31, 1984
                    • 2084
                    Dont know what the dia. of 205'S are compared to 7.75X15'S but as I said probably not driving nor than a few miles.
                    • John D.
                      • June 30, 1991
                      • 874
                      Originally posted by Kenneth Barry (7808)
                      Why not just put a original type spare in the well. Its not like you will be driving on it for a long ways unless you are on a cross country trip
                      Yes that's what I do. I have one that holds air I keep in the well. if I was going on a road tour I'd probably do something different. I have heard S10 mini spares work well.
