Paint removal
Re: Paint removal
I would be very careful with glass beads as they would cut the glass very easily. I had a soda blast companya and we did a few Corvette's again caution is the key and keep on eye on your air pressure. Also do not blast directly toward the car, blast more at an angle. I did my 65 Corvvette and once I started see the red oxide under the old paint that was my stopping point. You have to know when and adjust your air regulator to a lower p.s.i. than if you was blasting rocks or a steel car. If you are goung to do it see if the shop can give you some names of people who have had their Corvette's done by them and make contact with them and see what they say. Once you blast a hole in your fiberglass you are now screwed always better to little than to late. I had a set of old C1 doors I practiced on before tackling my car. I have some photos if you want me to send you some.- Top
Re: Paint removal
David
Damage illustrated below was done with a SOFTER media than you are proposing to use.
Media HARDER than surface is going to create issues. CF link below is source of attached photo and suggested repair methods.
David
https://www.corvetteforum.com/forums...ce-needed.html
A3778B00-ED04-4FD8-8D9A-F52621AB163D.jpgJudging Chairman Mid-Way USA (Kansas) Chapter- Top
Re: Paint removal
I blast ALL my cars with a fine black beauty and plastic
If you have a good operator and low pressure and know what your doing you can blast them clean with no damage
Here is one that had 7 layers of paint on it and the second sat out side for 40 years
IMG_0461.jpg1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
Re: Paint removal
I watched a YouTube video several months ago or more on this subject the company was media blasting a corvette with great results. The process was using a media that was harder than the paint but softer than the fiberglass.
I think the company was in Knoxville TN- Top
Re: Paint removal
I use a heat gun and a razor blade with great success to get down to the primer. Then use either acetone or paint thinner with 000 steel wool to remove the primer.- Top
