I have gone through two sets of HP water soluble decals trying to adhere them to my valve covers on a 61. I have used lacquer thinner and Acetone to clean off the valve covers. I will adhere the decals and they will be fine at first. After a while they curl off. I could use some suggestions so I do not keep going through them. Thanks! Mark
Method To Adhere HP Decals To Valve Covers?
Re: Method To Adhere HP Decals To Valve Covers?
I don't recall ever having an issue applying the decals. I used denatured alcohol to clean the valve cover area and then let the valve cover air dry. I also hold the decal by the corners and let it drip for awhile before attempting it to apply it. If you are having any issue with placing it in the correct position or straight, spray some dishwater soap (Dawn works well) mixed with water on the valve cover first. This allows you to slide the decal around without damage. When it's in place, gently blot it with a paper towel to help dry it.I have gone through two sets of HP water soluble decals trying to adhere them to my valve covers on a 61. I have used lacquer thinner and Acetone to clean off the valve covers. I will adhere the decals and they will be fine at first. After a while they curl off. I could use some suggestions so I do not keep going through them. Thanks! Mark- Top
