Anyone here have a '63 that can confirm cigarette lighter housing illuminates with headlight switch on? Quick...........go in garage and let me know. I have asked many knowledgeable C-2 members and get varying answers. Thanks, Bruce
'63 cigarette lighter lamp?
Re: '63 cigarette lighter lamp?
Yes My May 29th 63 had a light for the lighter socket.
Its been a while but this may be it in the pic, and yes, its a "gray whire" bulb so the dimmer rheostat for dash lights controls its brightness IIRC
If its not the lighter then its the ignition switch.Attached Files- Top
I have a 64, the cig lighter light illuminates if the parking or head lights are on - assuming the pull control knob that can be rotated to dim the instrument panel lights is turned up high enough to actually illuminate the instrument cluster light circuit.Ed- Top
Take a look at the 63 electrical diagram, all the gray wires are common and connected to the light switch for dimming While you are in that area do NOT forget to fuse the 14-R wire to lighter or burn baby burn!!!!
- Top
Yes, the lighters weren't fused until '67 IIRC and some repro lighter housings had a dangerous defect....possibly causing a dead short from the power wire spade lug to the housing, if that lug should somehow touch the side of the housing.
Although most modern accessories you plug into a lighter now are internally fused.Attached Files- Top
Appreciate all your responses. My next question is 'what does housing look like'? Frankie, I believe the circled part in your post is ignition switch lamp connection. There are several supposedly '63 lighter sockets on Ebay but only shows 2 grooves on outer connector............is that all I need and/or does lighter pick up illumination from surrounding gauge? Not sure if my description makes sense but willing to accept your critiques. Thanks again for any help, my OCD gets the better of me in my confusion! Bruce- Top
