�65 L84 plenum stamp - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2155
  • Mike M.
    • May 31, 1974
    • 8365
    • Michael G.
      • November 12, 2008
      • 2155
      garver1948@gmail.com
      • Mike M.
        • May 31, 1974
        • 8365
        • John D.
          • December 1, 1979
          • 5507
          • Michael G.
            • November 12, 2008
            • 2155
            • Chuck B.
              • August 31, 1987
              • 121
              chuck
              • Michael G.
                • November 12, 2008
                • 2155
                • Michael G.
                  • November 12, 2008
                  • 2155
                  Originally posted by John DeGregory (2855)
                  Michael, 1965's were typically stamped on the large v pad holding the vacuum advance fitting. Beneath the rubber hose going to the VA.
                  Typically is the key word. The chassis was slowly moving so sometimes the partial vin number was stamped closer to the right rear corner.
                  Sometimes stamped two maybe three times. The quality of the samping was typically poor.
                  Jim Gesner can tell you a lot more. . Al Grenningused to send me photos of stamping that were somewhat shocking.
                  I once saw an early '65 plenum stamped at the front of the plenum on the same pad that holds the balance tube clamp. Only ever saw that one time and I have restored a ton of '65's.
                  • James G.
                    • May 31, 1976
                    • 1556
                    www.vettefinderjim.com. Good examples there. As I understand, when the engine pad was stamped, the same vin stamp was stamped on the plenum.
