1963 headlight set screw
Re: 1963 headlight set screw
David, It looks broken to me. I would drill it out and if needed just drill a new hole and tap for a new Allen screw.- Top
- Top
It shouldn't be that hard to remove.....I would soak it overnight in PB-Blaster then try to drive the collar a bit farther on to the shaft with a wood block and tapping with a small hammer. Then lightly clean up the exposed shaft and drive it off the other way.Hopefully you all can forgive me. I’m new to the C2s so I haven’t dealt with the headlights before.
Seems I was trying to fit something to what I saw down deep in the set screw instead of on the top of it. I should’ve clean the surface better once.I cleaned it I could see the Allen head at the top of the screw not down inside it. Duh! It came right out once I found the correct size Allen wrench.
Now, any ideas on how to pull the collar off? Lots of Aerokroil and a puller?
Thanks all for your help.- Top
I agree with Frank. Yet another option is heat up the collar a bit with propane, then use a few seconds worth of CRC Freeze-Off on the shaft to shrink it. A 2 jaw puller would help too. Just protect the end of the shaft from getting burred up.
What you're likely also going to have a problem with is getting the pivot balls off of the shafts. Here's a link to a post on a '67 buckets do-over. Many photos in there so it'll take time to load.
https://www.forums.ncrs.org/showthre...879#post762879
Rich
PS Joe beat me to it while I was hunting for that post... lol- Top
It was an Allen set screw. Got it out.
Used this setup to remove the rest.Thanks for the help all.Attached Files- Top
It's amazing how seized those get. The AIM mentions oiling the felts, but likely only good for a year. Too bad they weren't made with Teflon sleeves.
Rich- Top
